Ok, I've been going through this GrassHopper...decided to pull the oil cooler and clean it. When I pulled the cooler off, a blocking plate fell out revealing the air hole for the cooler...am I missing something, or was the block plate inadvertently left in place?
With it in place, there was no airflow through the cooler...seems odd to me.
So, for you guys with the oil cooler, did you find an open hole into the flywheel or a blocking plate??
