Group 7 V2222
by GumbyJarvis - 04/09/20 03:56 AM
I'm looking for a 0w30 A5 B5 oil
by Marco620 - 04/08/20 11:57 PM
Does anyone put heat shrink tubing over a connector plug?
by motor_oil_madman - 04/08/20 10:39 PM
Anyone ‘excited’ for API SP/GF-6?
by addyguy - 04/08/20 10:30 PM
O'Reilly online learning for .gov email addresses
by spackard - 04/08/20 10:26 PM
Welding Helmet Fogging Up
by George7941 - 04/08/20 09:54 PM
Detroit 4-53T 2009 Ford F350 Update.:)
by A310 - 04/08/20 09:48 PM
Thoughts on CAFE standards
by otis24 - 04/08/20 09:20 PM
PUP amazon 5w-20
by Koncrete_Cam - 04/08/20 08:54 PM
Duralube Trans Shudder Fixx question
by soulburner - 04/08/20 08:36 PM
Number of Spare Magazines You Consider Adequate?
by 2015_PSD - 04/08/20 08:24 PM
Troy Bilt TB6044XP string trimmer dies when hot
by 92saturnsl2 - 04/08/20 07:18 PM
JD Yanmar deisel engine
by yankees1 - 04/08/20 07:14 PM
PQIA Looks at Leading 0W-20's
by Jackson_Slugger - 04/08/20 07:03 PM
Marine oil in a passenger car engine
by Thunderbolt - 04/08/20 06:50 PM
BG SAE 5W-30 Full Synthetic Engine Oil
by JonnySaab - 04/08/20 06:42 PM
Buying oil filters: anyone buy them online?
by 53' Stude - 04/08/20 06:03 PM
Rampage muscle truck
by gfh77665 - 04/08/20 05:57 PM
Why is exhaust stupid expensive?
by IMSA_Racing_Fan - 04/08/20 05:34 PM
edot1, Tori, siroisma, i4ni, Monica
71133 Registered Users
96 registered members (Aredeeem, 2009Edge, antone, 77GrandPrix, 4WD, 7 invisible), 1,440 guests, and 15 spiders.
Topics303,809
Posts5,242,239
Members71,133
Page 2 of 88 1 2 3 88
Re: post your latest transmission lubricant change. [Re: ledslinger] #2211970 03/25/11 08:04 PM
O
Oregoonian Offline
O
03' Ford Focus (2.3L Duratec) / 95K +
Complete flush...using Motorcraft Mercon V...about 35,000 miles ago. Still shifting beautifully.
Plan on doing an ATF change shortly... and adding a Magnefine filter. Unsure if I'll use Amzoil or Mobil 1 ATF (synthetic).
03' Ford Focus SE(2.3L Duratec PZEV)/ 140K +
Pnz. Ultra 0w20 / Fram 'Ultra'/ OCI: 8000 +/-
ATF: Mercon V w/Lubegard Red
Re: post your latest transmission lubricant change. [Re: m37charlie] #2212036 03/25/11 09:06 PM
L
ledslinger Offline OP
L
I "need" some pics of the Unimog.
Re: post your latest transmission lubricant change. [Re: ledslinger] #2212216 03/25/11 11:55 PM
crinkles Offline
amsoil 40% replacement for my tranny and diff... rest is T-IV
Re: post your latest transmission lubricant change. [Re: ledslinger] #2212250 03/26/11 12:39 AM
S_Walmer Offline
I changed my ATF in the hyundai about 2 weeks ago with amsoil.The fluid looked kinda red/brown I did a drain and refill about 4 qt, trans shifts smoother now. Did 3 drain refills about 2 1/2 years 25kmi ago with amsoil also. Fluid started looking a little dirty most likely the amsoil cleaned out some of the leftover crud or SP III from 2 years ago. Might install a magnefine in a couple months.
09 Volvo C30 127k Amsoil HDD,MTG, PSF, BF ,Sierra AF
14 Mazda CX-5 Touring 68K - Super tech 0w20 + Super tech ST6607 Sierra AF
Re: post your latest transmission lubricant change. [Re: ledslinger] #2212267 03/26/11 01:18 AM
cos Offline
'06 Ford Fusion with manual transaxle:
Amsoil: one qt of MTF and two qts of MTG
'15 Cadillac SRX
- Castrol Magnatec 5W30
- Valvoline Maxlife ATF
Re: post your latest transmission lubricant change. [Re: ledslinger] #2217563 03/31/11 07:19 AM
caravanmike Online Content
Online Content
since this is a brake forum also, i replaced the brake pads on a 2006 tahoe front and rear with napa adaptives. tranny fluid change is coming next oil change!
Oils I use: Any 5w-30,5w-20 conventional
Re: post your latest transmission lubricant change. [Re: ledslinger] #2217768 03/31/11 11:59 AM
E
EricF Offline
E
99 Ford Ranger
5qts Castrol Dex3, 1bottle Lubegard Green (dex3 to merc V modifier)
93 Ranger 4.0 5spd -- 3qts Genuine Motorcraft Mercon, 3oz ATP Synthetic protectant
92 Taurus 3.8L 5qts Shell Dexron/mercon 1bottle Lubegard Red (lifesaver!)
02 Altima, 4cyl, 4qts Castrol Multi-Import fluid.
Next: 06 Saturn Relay, Dex 6 (probably valvoline) and 1 bottle Lubegard Red.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
Re: post your latest transmission lubricant change. [Re: ledslinger] #2218088 03/31/11 06:26 PM
Donald Offline
Suburban and Jeep GC, both with Amsoil ATF and a Magnefine filter on the Jeep, and it will go on the Suburban soon.
2015 Ford F-250 w/Powerstroke
Re: post your latest transmission lubricant change. [Re: ledslinger] #2219168 04/01/11 07:31 PM
P
panthermike Offline
P
Have been doing Drain/fills on the Corolla since around 30K. Did 3 drain/fills w/ Schaeffer's ATF and didn't like the shifting.
More recently:
-6.6qts Maxlife(2 drain/fills).
-8oz. of Lubegard Red.
I will soon drop the pan and replace the ATF filter.
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
Re: post your latest transmission lubricant change. [Re: ledslinger] #2219503 04/02/11 07:14 AM
P
pavelow Offline
P
04 Jetta 01M trans.....3 liters VW ATF and VW filter.
97 Jeep TJ 32RH trans.....4.5qts Valvoline ATF+4 and NAPA filter.
Re: post your latest transmission lubricant change. [Re: ledslinger] #2219583 04/02/11 08:58 AM
FordSVTGuy Offline
Hyundai Entourage, 59,000 miles just completed ATF drain and refill with filter change. Took 5qts of SP III ATF.
2006 Ford Mustang GT
2012 Ford Escape - Limited
2013 Ford Explorer XLT
2014 Ford Focus SE Hatchback-5 speed
Re: post your latest transmission lubricant change. [Re: ledslinger] #2219647 04/02/11 10:47 AM
W
WishIhadatruck Offline
W
500 miles ago I dropped the pan and replaced the filter in my Grand Prix. I do it every 30k miles.
AC Delco Filter
8 qts of Valvoline Dex VI
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
Re: post your latest transmission lubricant change. [Re: WishIhadatruck] #2220077 04/02/11 05:48 PM
SuperDave456 Offline
1998 Ford F-150 4.0 v6
7 quarts total, mix of Supertech Merc V, Mobil 1 multi vehicle, and Valvoline Maxlife with B&M in line transmission filter. 1 bottle of Lubegard Red.
Also did the rear diff. Used Amsoil Severe Gear 75w140 as in the manual.
107,000 miles and still running
2004 Ford Taurus 3.0 Vulcan
7 quarts Valvoline Maxlife and 1 bottle Lubegard Red
Also has Magnefine Filter
168,000 miles and still running
2001 Ford Taurus 3.0 Vulcan
5 quarts Valvoline Maxlife and 1 bottle Lubegard Red
Also has Magnefine filter
(this was along with a full tune up)
140,000 and still going
I dropped the pan and did filter changes on all of them along with placing some high temp neodymium magnets in the pan to increase magnetic capabilities along with the magnefine filters.
Re: post your latest transmission lubricant change. [Re: ledslinger] #2220157 04/02/11 07:01 PM
W
wn1998 Offline
W
Drain and fill on the Versa (4-speed Automatic) with 4-quarts of Mobil 1 Syn ATF. The drain plug is so convenient! Why don't all cars have an ATF drain plug?
09 Nissan Versa 1.8L (138K) 5W30 (6-month SYN OCI)
14 VW Jetta SE 1.8L Turbo (37K)
Re: post your latest transmission lubricant change. [Re: wn1998] #2220323 04/02/11 09:37 PM
L
ltslimjim Offline
L
In the year 3,000.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
