Originally Posted By: unDummy
Still irrelevant. Nice pictures btw. But, means nothing.
Curious why you feel it is irrelevant? Borg Warner/Tremec seems to disagree with you. And they manufacture it. (This feels a lot like our Ford oil filter discussion, LOL!).
I've owned both trannies. And killed both trannies.
When I got my '87 GT, it had a rebuilt tranny in it. WC T5. Whoever did the rebuild had put gear lube in it instead of ATF. It was an absolute nightmare to shift. It would grind when cold, and shifts were difficult.
I replaced the gear lube with M1 ATF and the transmission shifted like it should. No grinding when cold, smooth shifts....etc. It worked beautifully until a 5K launch on slicks twisted the yoke and shifted the guts of the tranny back 3/4".
After the first tranny went, I used a 4-cyl T5 in there for a while. It was spec'd for gear lube. I put ATF in it and it ground and had notchy shifting. A little Lucas in there to thicken things up and it shifted properly.
Then I wrote off the car, pulled the drivetrain, and put it in the Capri roller I bought. Back to the WC tranny with M1 ATF
Anyways, my experience with the T-5 is that the WC variant likes ATF (which is what it calls for), and the non-WC appears to like something slightly thicker. Not 80w90, but something a little heavier than regular ATF.
