2005 Suburban Z-71 88k miles w/ Original Diff and T-Case Fluids.
Rear diff 10-bolt w/ Eaton G80 locker and 3.42 gears.
The front diff calls for 80-90w and rear 75-90 Synthetic.
I need to spend $10/quart or under.
I have seen M1 and Castrol Syntec 75-90 under $10/quart.
Can I put 75-90 in the front or stick with the recommended 80-90w?
For rear diff should I use a Fel-Pro gasket or RTV Sealant?
Your thoughts, recommendations and experieneces please.
Thanks
Thanks
