I've had OK results with a solvent cleaner...jack up the drive wheels, add the solvent, run the engine for 15 minutes while shifting gears (brake the drive wheels to a stop before changing direction), drain, flush, refill the transmission. If the transmission isn't failing, this might work. If it is failing, nothing will work. I prefer Auto-Rx.
