Actually the P1's I've cut open, 14610 and 14459, the pleats are not that deep at all, only ~3/8". Not deep compared to many others. And wavy media in and of itself means little.
Also, had one thoroughly read daman's measurements, a second measurement was done with the texture removed and the P1 was on par with many others, including the Napa Gold. Only the Fleetguard showed a major difference in can thickness.
But as has been said, don't like the P1 (obvious now, though not from initial post) don't use it, that simple. But, post a sensational thread topic, expect serious and critical response. The bottom line here is, neither the can nor the media failed.
