repacking the bearing on my boat trailer. Using mystic hi temp #2 and have a question. this seems really tacky and hopefully it is a very good grease. What has me concerned is this considered a hi, med or low viscoisty grease?
After reading on a trailer manufactures website it said to use a low or med viscosity grease so that it will "flow" enough to lub ethe bearings. it said a high visc grease will be slung to the outside of the hub,
here are the exact words.
Be sure that the grease you use is a low to medium viscosity (high temperature) grease. Low to medium viscosity grease will flow around and through the hub cavity and bearings providing more total lubricant to the bearings than a high viscosity grease. High viscosity greases tend to centrifuge to the outer hub cavity wall where they stick and stay with only the small amount of grease in the bearing rollers providing lubrication.
