Oil is Mobil Drive Clean dino, 10W30, slightly pre-SL. "Exceeds proposed API SL/ILSAC GF-3 Specifications"
Added 5oz IXL additive.(*)
Analysis by Schaeffer's St. Louis Lab
92 Dodge Ram 150 2WD Pickup
5.2 Magnum V8
Miles on engine: 124000 (approx)
Miles on oil: 2000
Oil Filter: Purolator PureONE 14670
Air Filter: Purolator paper
Copper: 3
Iron: 18
Chromium: 0
Aluminum: 3
Lead: 5
Molybdenum: 52
Phosphorus: 639
Zinc: 633
Magnesium: 54
Calcium: 913
Antifreeze: 0
Fuel: 0
Water: 0
Silicon: 8
Viscosity: 8.88 (heavy 20W)
Sulfur: 42
Oxidation: 7
Nitration: 9
Contamination and additive depletion levels normal. Maintain current oil drain interval.
(*)I suspect the moly is from the IXL. Other drive clean samples haven't shown this much. Also, shortly after the IXL went in the engine started producing small amounts of white smoke under hard acceleration, hence the early change.
From their packaging:
"The anti-friction metal conditioner - IXL conditions the metal not the oil. ...is not a lubricant fortifier such as graphite, moly, or tfe. ...can not build upon itself. ...will not change tolerances. ...will not affect oil filters."
Nothing about white smoke.
David
5.2 Magnum V8
Miles on oil: 2000
Copper: 3
Iron: 18
Chromium: 0
Aluminum: 3
Lead: 5
Molybdenum: 52
Phosphorus: 639
Zinc: 633
Magnesium: 54
Calcium: 913
Antifreeze: 0
Fuel: 0
Water: 0
Silicon: 8
Sulfur: 42
Oxidation: 7
Nitration: 9
David
