Amateur Paint Questions
by The Critic - 11/18/19 04:15 AM
What the..
by Mad_Hatter - 11/18/19 03:53 AM
Neighborhood Etiquette
by The Critic - 11/18/19 03:41 AM
AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1ยข at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
37 registered members (BillyE, Aichiguy, A_A_G, AurionX2, AZjeff, 92saturnsl2, 5 invisible), 608 guests, and 16 spiders.
Topics297,572
Posts5,118,220
Members69,899
Most Online3,589
Nov 2nd, 2019
Marvel Mystery Oil On Guns #2139080 01/15/11 08:45 AM
Dwight_Frye Offline OP
I'm reading an interesting new book titled "Hemingway's Guns, The Sporting Arms of Ernest Hemingway". In the chapter on his Winchester Model 12, a 1928 manufactured 12 ga. with a 30" full choke and solid rib barrel, it mentions that Hemingway was a big fan of Marvel Mystery Oil as a lubricant. The well used pump gun was said to be so slick that the corncob forearm could be worked back and forth with one finger ! Hemingway literally wore it out before trading it in on a newer Model 12 in 1958. Marvel Mystery Oil seems to have a pretty big following here on BITOG and while I would use more modern lubricants on my firearms, it seemed to work well in that application back in the 30's though 50's.
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2139110 01/15/11 09:24 AM
G-MAN Offline
The MMO probably had little to do with how slick the action was on that Model 12. The Winchester 12, along with the Remington 31 and the JC Higgins 20/High Standard Flite-King, were famous for their incredibly slick actions right out of the box. No modern day pump action can even come close (with the possible exception of the Ithaca 37).
2007 Mercedes ML350 (Mercedes 229.5 5w40)
2019 Camaro 1LT 3.6 (RLI 5w40 HD Low Ash)
Re: Marvel Mystery Oil On Guns [Re: G-MAN] #2139125 01/15/11 09:38 AM
Camu Mahubah Offline
Myth Busted! Cha Ching! Big fan of Hemingway. If you have not read the "The Short Happy Life Of Francis Macomber" than you have not read anythang at all...
Re: Marvel Mystery Oil On Guns [Re: G-MAN] #2139185 01/15/11 11:01 AM
A
Al Offline
A
If you got a good one you could point it up in the air and depress the Slide release and the Action Slide would drop all the way down.
Dad's 20 Ga. Model 12 never quite made it but his Model 12 Gauge did.
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2139209 01/15/11 11:24 AM
U
unDummy Offline
U
My neighbor took his kids to the range a couple months ago. Went through 100's of round of ammo in multiple rifles. When I went over a couple weeks ago, he still hadn't cleaned them. All he had was MMO in the garage. It did a great job of cleaning/lubing his bolt and lever action rifles, along with some wheel bearing grease in the higher load/wear areas. MMO is a great basic cleaner and lubricant.
Re: Marvel Mystery Oil On Guns [Re: Al] #2139346 01/15/11 01:44 PM
G-MAN Offline
That was true of all three of the guns I mentioned. Take a look at the blue highlighted section of this old High Standard ad:
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2140280 01/16/11 12:05 PM
H
HyperJinx Offline
H
I see no reason to use MMO on any of my firearms. Google will tell you want is in MMO, and its not what I would or have ever used to clean/lube firearms with. There are just too many quality and gun specific cleaners to start trying to experiment in my garage.
2007 Corvette (Synpower/M1 filter) 2001 Silverado (Syntec Blend/ PureOne) 1969 Camaro (Rotella T/Napa-Wix)
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2140738 01/16/11 07:29 PM
U
unDummy Offline
U
Most of those quality and gun specific cleaners ARE garage experiments. Many are grossly overrated and seriously overpriced for what they are.
Re: Marvel Mystery Oil On Guns [Re: unDummy] #2140796 01/16/11 08:01 PM
Pablo Offline
I dunno about MOST, but I agree with you.
Up until now, all I ever used for cleaning and lubing my guns for 25 years:
Hoppe's #9
Military Surplus (1969) "Rifle Bore Cleaner "MIL-C-372B"
Military Surplus "Weapons Oil, Light"
And more recently maybe a little Amsoil grease and Amsoil MP.
My guns look pretty nice.
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2141028 01/17/11 05:10 AM
M
Mr_Joe Offline
M
I do like a little Royal Purple 5w-20 synthetic lightly applied on my AR bolt when operating in a high round count SD dogtown. It sticks around longer & keeps things running. I do have a years old container of MMO in the garage looking for a use though.
Re: Marvel Mystery Oil On Guns [Re: Mr_Joe] #2141229 01/17/11 10:37 AM
SuperDave456 Offline
Also please remember that there is some Marvel Mystery Oil that is out there that is a Lubricating Oil.
For some reason I don't see it often.
The last time I saw it was at Northern Tool, which actually has a decent supply of lubes along one of their back walls.
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2141327 01/17/11 12:26 PM
B
bigmike Offline
B
I've used Marvel's lubricating oil from an aerosol can. It stinks, but it works great for lubricating nuts/bolts/etc. They also make one in a bottle. Doubt I'd use it on my weapons.
Take care,
-Mike
2006 Chevy Silverado LT 4.8 - QS 5w30, Napa Gold
2009 Honda Accord LX-P 2.4 - QS UD 0w20, P1 14610
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2141332 01/17/11 12:34 PM
demarpaint Offline
MMO is a good lube and does a pretty good job cleaning powder fouling. It does not work as a stand alone product. It does well with carbon fouling and as a gun oil. You still need a good solvent for cleaning copper fouling, etc. It works well at preventing rust. I've removed rust from bluing with it too, which BTW is a form of rust IIRC.
God Bless Our Troops
Re: Marvel Mystery Oil On Guns [Re: Dwight_Frye] #2143112 01/18/11 09:17 PM
L
Loobed Offline
L
I mix 50/50 MMO and Hoppes #9.
#9 is too expensive, and it isn't needed full strength if you take care of your gun.
Re: Marvel Mystery Oil On Guns [Re: Loobed] #2143563 01/19/11 11:34 AM
O
Oil_Can_Harry Offline
O
I have an older Remington 572 fieldmaster pump .22 and the owners manual for that vintage gun recommends varnolene or kerosene for cleaning and light machine oil for lubrication. Under extremely cold conditions some powdered graphite can be used in place of the oil.
2000 Toyota Tundra reg cab SR5 V8
2009 Mercury Grand Marquis LS
