****BITOG's FAVORITE OIL 2010 RESULTS****
Earth
I'm Finally done!
Here are the results!
Code:
Oil Times used Percentage
Pennzoil 346 25.40%
Mobil 1 263 19.30%
Vavoline 169 12.40%
Castrol 131 9.60%
QS 97 7.10%
Motorcraft 68 5.00%
Rotella 41 3.00%
super tech 31 2.20%
Amsoil 30 2.20%
chevron 26 1.90%
havoline 18 1.30%
Napa 18 1.30%
Royal Purple 15 1.10%
Schaeffers 14 1.00%
Toyota 14 1.00%
redline 10 0.70%
petro canada 10 0.70%
o'Rielly 7 0.50%
peak 7 0.50%
kendall 7 0.50%
motomaster 6 0.40%
trop artic 4 0.30%
Motul 4 0.30%
Honda 3 0.20%
Carquest 2 0.10%
RLI 2 0.10%
Esso 2 0.10%
76 2 0.10%
liqui moly 2 0.10%
exxon 2 0.10%
ace 2 0.10%
Eco power 2 0.10%
Cam2 1 Trace
costal 1 Trace
Brad penn 1 Trace
wolfs head 1 Trace
There was a total of 1359 oil changes.
As far as syn or dino & oil filter used, sorry. I didn't have time.
Originally Posted By: crinkles
Nice! is shell included in Pennzoil?
For whatever reason, he has Rotella listed separately, and that's Shell, too.
i appreciate the hard work!! but would have liked to seen labels separated, ie edge from castrol etc
Thanks for the work. If you have time and the data perhaps you can divide the Dino from synthetics.
Perhaps BITOG isn't that different from the rest of the world. I'd bet that if the numbers are crunched Pennzoil is the top dino and Mobil the top synthetic on BITOG.
The top 10 fell just about where I figured they would. Thanks for taking the time, you should tally them up for 2011 too!
I would have never for the life of me thought that Pennzoil would win out in this forum.
Thanks Troy for taking the time to put it together!!! Says a lot about you and your passion for motor oil!
"Pennzoil" would have included both dino and synthetic oil sales? Not surprising at all if that is the case......
Pennzoil sells lots of both!!
It would be interesting to know the breakdown of Pennzoil sales.... but our scribe is probably exhausted!
All, yes Shell is included in Pennzoil, but I listed Rotella seperate because it is supposed to be used for a different application.
I was suprised to see SuperTech up as high as it was
I do not have the data, but I can tell you ALOT of the oils WERE synthetics, and a P1 filter was common, along with a Napa.
Originally Posted By: Doug Hillary
Hi,
DT466E - Great effort - thanks
Keep the DT466 going - great power plant series!
Thanks! Sadly, it has to go after this year(age limit, who knew
), no telling what I will get next.
Originally Posted By: daman
Not accurate unless all 33,000+ members posted,but still nice job.
i didn't vote..
Do you know how glad I am all 30,000 didn't post?
There was no voting.......all this came from Jan 1, 2010 to the end of the year on the Post your latest oil change thread.
