Well... get this:
Here's an email exchange I had with Valvoline "techs".
I had to pack the front wheel bearing on my Harley Davidson motorcycle.
The manufacturer recommends doing this every 10,000 miles.
I used Valvoline Durablend semi-synthetic wheel bearing grease. Everything
went well.
A Harley Davidson dealer says that I should have used Harley's house brand
wheel bearing grease because it is waterproof, and many other brands are
not waterproof.
Is your Durablend semi-syn wheel bearing grease waterproof, and is it a
satisfactory lubricant for the wheel bearings on my Harley Davidson
motorcycle? (It's a 1994 model Low Rider if that helps.)
Thanks,
Dan Newberry
And Valvoline's answer in its entirety:
Thank you for your question! Valvoline recommends that you continue to use
the Harley Davidson grease.
No kidding. That's it.
So what do we make of this? Are they saying their grease is crap? Or do they believe it won't properly lube the bearing in a Harley Davidson's front wheel? Or are the Valvoline "techs" just too darned sorry to research the needs of the HD wheel bearings so they just tell me to stay with the Harley grease.
Totally crappy answer. I doubt I'll ever purchase Valvoline products again...
Dan
