Nobody seems to think that the master cylinder is bad unless it is leaking. To be fair, the shop that was advocating a shim behind the flywheel never got to inspect it, and hopefully woudl have done the MC. I was going to do the MC a couple months ago but they didn't think it would be the problem.
Next clutch better shim it though as the pedal is lower than ever before. I am amazed that sucn minimal differnce can make such a difference in the clutch pedal. Also, instead of shimming the flywheel, would make more sense to put some thin washers behind the slave when mounting it to the front of the tranny. It needs a big inspection plate that can be removed, then the slave could be shimmed wihtout dropping the tranny.
New clutch, new brake lines, a lot of other new stuff, this truck is ready for another 100,000 miles if the leak above the windshield is not the kiss of death! I don't ever want to give up this truck, wife hates it and it will be a battle to get another manual tranny as she won't/can't drive it. Funny thing she drove her brother's 3 on the column station wagon many years ago in teh snow Wisconsin winter and got from point A to B.
