I spent a few hours this morning installing a new converter in my old Legend. I think it took longer gathering up new nuts and bolts than actually doing the R&R.
As corroded as the self-locking nuts were, a little PB Blaster and a breaker bar prevented a groin strain.
Looks like the factory installed converter was made in the same place they made Japanese battleships in WW2. Might have been a left over torpedo body?
Installed. It looks like it should be installed with the attached heat shield facing the ground. But this is the only way it would bolt up. I re-used the old lock nuts; I decided not to use the new flange nuts I bought. I was unable to locate new 10mm lock nuts. Lock nuts with the nylon inserts were a dime-a-dozen, but nylon is NOT good for this application. No provision for re-installing the OEM lower heat shield.
CARB Exemption Number (Top Line). This is what we pay extra for in CA.
Emission re-test will be next Saturday. Hopefully, this will bring the HC numbers back in spec.
