I'm looking for a special type of grease ... and not any will do.
My dad has an old Model A Ford and the water pump has a grease fitting on it and what is needed is a very high heat and high-pressure grease that is VERY water-proof.
The stuff I had used was called "STA PUT" and was distributed by "Smith & Jones" but the 1 tube I had ran out.
Here is what is written on the empty tube:
STA PUT
Heigh Temp / Extreme Pressure
Water Proof
Other specs are:
550 Dropping Point
65lb. Timken OK Load
Rust, Corrosion & Oxidation inhibitors
Water resistance
Ideal for Water Pumps.
This grease is very heavy, very sticky and dark green in color. It is not a opaque color like most but instead it is translucent ... almost transparent.
Anyone know of any comparable greases? I don't need any immediately but I like to keep one gun around the garage loaded with this stuff.
STA PUT
Water Proof
Other specs are:
550 Dropping Point
Water resistance
