I've been thinking about switching from a 15W50 to an oil that will flow better in the cold in my Buell 1125R (and probably in my Daytona 675 and CBR600F2 as well). The big concern with 40-weight oils in bikes is their shear stability and I want to make sure whatever I use will hold up. The Amsoil 10W40 motorcycle oil is reputedly very shear stable and seems like a solid choice. But then there's the 0W40 which is also marketed towards power sports with wet clutches and shared transmission lubrication. The 0 rating would be even better for cold starts so.. is there any reason why I shouldn't use the 0W40?
