Should I try some Mobil 1 15W-50? Synthetic, diesel-rated xxW-40 oil is blowing through the engine.
'97 Civic is spec'd for 5W-30. Anything but 15W-40 Diesel seems to get shredded within a couple/few hundred miles, and just blows right through the engine.
I was using 15W40 Rotella this past summer. Now using 5W-40 T6 Rotella full synthetic, because weather is colder + winter coming to New England. But the 5W-40 is blowing through the engine.
Added 8 oz Valvoline 20W-50 syn. blend and oil burning is now tolerable. Not sure what I should put in, OCI is coming up very soon. Maybe go back to 15W-40 conventional, never mind that it will be zero degrees outside.
I have a 50 mile commute each way so mostly the engine is running warmed up. If it's burning, I think it must be happening when warm, with oil behaving at its "summer" viscocity.
