Originally Posted By: Stu_Rock
Originally Posted By: ArrestMeRedZ
I've got a '02 F-body, a model that was famous for warping rotors. Mine warped well before 10k miles.
This surprises me, considering how huge the pads are on F-body brakes. Is it known why F-bodies are "famous for warping rotors"?
I just swapped F-body calipers onto my Park Avenue, which has stock pads that are half the size. The heat buildup on those did lead to warpage.
I replaced them with Brembo blanks (not drilled or slotted) that were made in Mexico (previously made in Canada).
Brembo...interesting. I didn't think to check on their country of origin. After I received my Chinese Wagners, I checked Raybestos, Até, Centric, and the cheapies (F-bodies and C-bodies use the same rotors).
I'm not sure about the LT-1 Camaros (pre '98), but the problem was common on LS-1 Camaros and Firebirds. I know my wife's '98 V-6 never had a problem. The LS-1/Z-28 message boards were rife with reports of warped rotors. I was expecting the problem, and I wasn't dissapointed.
After a lot of research, I concluded the Brembo blanks seemed to have the least problems. Slotted or drilled rotors were universally regarded as very bad replacements. I knew about the country of origin as I needed the replacements badly (the front shook like a washing machine with a bowling ball in it on spin cycle), and I had to wait as Brembo moved it's production to Mexico. That was a few years ago. For all I know, they could be made in China now.
GM put out a TSB on the problem. Their "solution" was to turn the rotors, after checking run out. Everybody I knew that had that done had warped rotors again within a very short time. I didn't even bother to try for a warranty replacement.
