Originally Posted By: motorcity
No it was stuck in the hub bearing, but I was able to finally get it out. I have the knuckle off the car, now. I was thinking about taking the outer CV joint apart and useing it to hammeer the beaaring out.
The next time you need to free the axle splines from the hub splines, back the axle nut off passed the end of the axle shaft and start striking the nut with a sledge hammer. Keep swinging the hammer until you see the axle shaft move inward. When it's free, it'll move inward with each consecutive hammer strike and then spring back out after each strike. You have to be watching carefully as you strike the axle nut with the hammer because if you don't, you won't see when the axle breaks free and you'll be hammering on it even though it's already free. It needs a 4 lb. hammer minimum, but ideally, an 8 lb. hammer is the way to go. The axle nut will be toast, but the axle shaft will be fine.
