While most 15/40s hold up pretty good there are several 20/50s which maintain there wts also.If you check some of the uoas there are some samples of Amsoil and mobile 1 v twinn oils that actually tend to thicken up with use and age. There even was a sample of Brad Penn oil that performed the same.If your bike uses the oil in the motor as well as the trans, that type of use tends to shear oil fast. But whats most important is to use what weigh the mfgr of your bike specs for the bike.Harley for instance recommends 20/50 wt normally, but says to use 10/40 when the temps are under 40f.As well as using straight 50 wt and straight 60 for when it gets really hot.,,
