I changed the OEM fluid and filter on the transmission on our 2005 Saturn L300 last month. It has the 3.0L DOHC v6 and the 4 speed 4T45E transmission. Car has 89,000 miles on it.
OEM fluid came out pretty clean looking and there was little material on the magnet or on the bottom of the pan.
I refilled with Valvolines MaxLife Dex/Merc. It shifted fine the first day, but then started flaring up occasionally between 1-2 and generally not feeling like all of the power was going to the wheels.
Tonight for giggles, I started the car and took out the inspection plug (no dipstick on the 4T45e folks!) and lone and behold, it was 1/2 quart low, so I topped it off.
Would a transmission that was 1/2 quart low cause shifting problems? It seems that an amount that small would be negligle but I want to be sure!
