As I mentioned in demarpaint's thread...
My 4.8 GM doesn't have a drain plug. I referred to my Hayne's manual and it shows one, with a hose. However, after crawling under the vehicle and observing from the top, I notice the following:
1. I don't have the hose that is used for draining.
2. I notice where the drain plug is SUPPOSED to be. It has an indentation hole into the radiator, but there are no threads or ways to turn it. It appears to be smooth like it's all one piece of the radiator housing. I verified this with my finger and observation with inspection mirror. No way can I fit my head into there to actually SEE it.
3. There's a hose nipple at this same location for the said hose.
I'm perplexed. Why would they go to all the trouble making the location for the hose and indentation for the drain, but not supply me with a usable drain cock?
It appears to me the only way I'm going to be able to drain it is pull the lower hose. Since this is the first time I've done this on this truck, will I need to do anything special? Remove the thermostat or no?
Keep in mind all I want to do is drain the radiator, not flush it or run a hose through it (if I can avoid it). Fluid is pristine for 5 years old. I've got several gallons of Zerex Dexcool 50/50.
