I have an '03 X-Type Jag which uses a Jatco automatic transmission.
These transmissions are "sealed for life" at the factory (although they do have a drain plug and a fill tube but no dipstick) and empirical evidence is that "life" is something short of 100K miles whereupon the Jag dealer whacks you for about $5K for a new tranny or you find a good used one or you get another car. There is no tranny rebuild information in the Jag technical data on the car. The tranny has no filter but there is a procedure for draining and replacing the "sealed for life" fluid if the car is subject to "severe use".
Problem is, the tranny calls for "JTIS Spec: WSS-M2C922-A1" and I can't find anything that says it meets that spec. The original fluid is Jatco 3100 PL085 which the local dealer will sell you for about $50.00/qt and you need a little over 9 qts so a fluid change costs around $500.00 just for the fluid!!!!! (There is some information that the Jatco fluid is IDEMITSU K17 transmission fluid, equally unavailable on this side of the pond.)
So, the question for all you oil & fluid mavens is: what available fluid meets this spec and is compatible with the original fluid, since complete flushing appears to be just about impossible. I've researched Red Line, Mobil 1, Royal Purple, Valvoline, etc. including contacting them by email and on the phone where possible but no one comes right out and says their product meets or exceeds the spec.
So, what's available that meets or exceeds the spec or where can I get Jatco 3100 PL085 or IDEMITSU K17?
Thanks in advance for the help.
