I'm thinking that MoS2 can reduce consumption by possibly filling tiny scratches and voids on the cyl walls. It stopped my mower from smoking on start up for two full seasons now. Others have reported reduced oil consumption as well. I would think that the oil use might resume if the MoS2 is discontinued for a few OCI's, because any residual coating that is filling the voids would probably wash out. Just my thoughts.
The more I read and learn about oil and additives, the more I question the many things taken for granted as "fact." In older engines like my Toyota or your Aerostar, API SM did not exist and different standards were called for (mine is SJ rated).
Of course, every SM oil (or oil before it) was back spec'd to meet or exceed the requirements of the previous API standards; yet the additives have changed, as have the amounts allowed in the different specs. In SJ oil moly was common, while in SM oils the limit is pretty low, and if you look at the additives in SM rated oils, you'll find in many cases no moly at all, or when you do, small amounts.
But that's okay say the "authorities" on this subject, because we are told that whatever they're using instead is at least as good or better.
Same thing with ZDDP. Too much is poison to the cat, yet my SJ rated engine allows for more ZDDP than any SM rated PCMO. And I can get more from an SJ rated HDEO (which many are), along with more moly too. But not at the same sale prices I find my PCMO oil at, so I'd wind up paying about double.
And keeping in mind that these SJ API rated HDEO oils are used on half million dollar pieces of equipment (where the API spec has no relevance) that see far heavier duty use than my car, I really wonder more and more about the new and improved spec. Better, sure - but for who.
I personally have been beginning to think my car would be better served by something with an additive package closer to the SJ spec it was designed to run on. Ideally an HDEO, but with the price difference, I'm willing to experiment with quality additives to change the oil I have now into something resembling closer to an SJ additive package. I'll keep the better quality base oils from this PCMO, but my reservations about tinkering with it are slowly going out the window.
It already has more moly (thanks to mos2) and I think that's a good thing. Next up is to boost the ZDDP with the right additive. After that and Motor Oil Saver go in, I'll have my own personally formulated HM & HDEO style PCMO.
People will think I'm nuts, but I don't care. I think my car will be better off for it.
Those who are terrified of additives or believe whatever PCMO oil they buy is pre-blended to perfection and shouldn't be messed with can voice their condemnation to my deaf ears.
-Spyder
