A simple job to replace the fuel filler hose on my motorhome (approx 4' by 2" ID) has come grinding to a halt. The motorhome is on a Chevy van chassis with a 454 V8 year 2000 (maybe 1999 for chassis). Anyway, when I pulled the filler hose off the neck there is another hose maybe 1" or so diameter inside. I tried pulling the filler neck and smaller hose out of the big hose but is wouldn't give, must be connected at the tank, so.... What to do? My replacement hose does not have the internal hose as it is a generic hose. My Haynes manual does not indicate the internal hose, but is for vans, not motorhome chassis.
Can this work without the internal hose?
How is the internal hose hooked up at each end, hard to tell as bigger hose won't pull back enough to get a good look.
Am about to run it into the shop.
Any help appreciated, thanks, Paul
