I'm trying to find a cross reference resource that will tell me which filters are oversized. I'm listing Fram part numbers to make the cross reference easier, even though I use mostly M1s or Fram TGs (I know, I know, I'm getting rid of them). After all the great research here I'm going to use Bosch filters moving forward, but want to get all the part numbers in order and place one huge order from RockAuto.com.
First a few thoughts-
The advantage of going to a bigger filter is the additional filter media does not TRAP more matter, but HOLDS more matter. So with OCI of about 3500miles this isn't really an issue.
The RISK with going with a larger filter changes the spring rating of the bypass valve, which may increase the oil pressure and/or restrict oil flow, again, not an issue if the OCI is short enought to not completely clog the media and trigger the valve.
The other risk, is of course screwing up size and ending up with crossthreaded filters, or bad seals that squirt oil. I'm tempted to go to Kragens and open boxes and hold the filters against eachother to verify a good seal.
I don't think the anti-drain back valve is affected by a larger filter.
The first one is for my wife's 2005 Infiniti FX35. When I first saw the tiny filter I realized it's the same size for my 800cc motorcycle filter! The stock filter is Fram PH6607 or Bosch 3300. I'd like to find something bigger, mostly because the engine is higher milage, and now that I'm running Mobil Clean 5k I want to push to 4500m OCI. Compared to my Honda motorcycle I can't believe this size is sufficient for a 3.5L V6.
The second filter I'd consider upsizing is for my Jeep SRT8. The stock filter is Fram TG16. This filter is freaking huge, so I don't think it needs to be bigger. The OCI is 3000mi. I've been using M1s, but $12.50 each is silly, I'm switching to Bosch.
The last filter is for my motorcycle 2002 Honda VFR800. The stock filter is Bosch 3300. I have been using Bosch 3323 with no problems. It doesn't get many miles, so next oil change I'll send a sample to Blackstone.
Thanks for any feedback!
