A friend of mine over in Germany was using oil from the PX he got an American friend, he ran it like he would German full synthetic and ended up with a very minor sludge problem.
Last year i brought him 2 bottles or ARX (when i still drank the Kool Aid).He ran it for 6k km,he reported the engine is making horrible noises. This trip i took a look at it and found ARX has broken off small pieces instead of liquefying it.
The small filter for the VVT was totally plugged.
We changed the small nylon filter but the noise is still there, it appears mechanical damage is done.
I feel quite the fool for recommending this stuff to him. Now i am bringing some Kreen back late next week when i return although it probably won’t do any good at this point.
The majority of the deposits remain in this engine, very unsatisfactory results in fact the results could not be worse.
The engine is a 1.4 in a 2003 Toyota Corolla, the 1.8 U.S. engine also uses this small filter. Anyone considering this product in a Toyota 4 with said filter should take note.
Info: The filter is on the side of the block behind a 14mm bolt behind the alternator.
