Did an oil change and tire rotation on my wife's Mazda3 today. Seems like whenever I do work on the cars it takes longer than I feel like it should -- especially this one when it comes to oil changes. By the time I:
- Jack the car up (a multi-step process with this car)
- Deal with the under-cover/splash guard
- Mess with the cartridge filter
- Rotate the tires including looking at the brakes/suspension/etc. and brushing the rust off the hub mating surfaces
- Drain and refill the oil, run the engine for a few minutes, and check the level
- Clean up
it seems like I've been out in the garage for a couple hours! Seems to me at least twice as long as it should take. I'm not sure if I'm meticulous or just slow. I suppose at the end I have saved money and I know that it was done right, but it still makes me wish a little bit that I could bring myself to take the vehicles in for maintenance.
How long does it take you guys to do routine maintenance?
- Clean up
