I've always used regular fuel to mix 32:1. Recently purchased a Stihl chainsaw with with 4 stroke engine that uses 50:1 fuel mix. Owner's manual specifies mid octane fuel. Why? Seems to me the oil is already going to raise the octane (make the fule less easy to ignite). In the past, using higher octane fuel with fuel mix was a sure way to foul spark plugs. My first few gallons in this machine and my other regular 2-cycles was with regular octane and Stihl Ultra, but my last mix was with mid grade and so far not a danged bit of difference. I do cheat and mix 32:1 so the same fuel is suitable in all of my chan saws and brush cutters - seems fine in all including the new 4 stroke oil burner.
