Bond Arms Rowdy
by faltic - 11/22/19 01:12 PM
Question about stored vehicles
by loneryder - 11/22/19 12:53 PM
Camry exhaust downpipe
by supton - 11/22/19 12:30 PM
What is your favorite airline and why?
by ZZman - 11/22/19 11:35 AM
Costco Instant rebate for M1
by Joephu - 11/22/19 11:25 AM
Serpentine belt
by Grambo - 11/22/19 10:50 AM
My 2016 Ford Fiesta Failure
by Mr_Luke - 11/22/19 10:37 AM
Starter Tool set - hand tools for professional work?
by btanchors - 11/22/19 10:20 AM
Acceptable amount of time to get up to speed?
by ls1mike - 11/22/19 09:35 AM
Paint question
by supton - 11/22/19 09:31 AM
SUV tires vs passenger car tires
by Ded Mazai - 11/22/19 09:00 AM
Crysler Crossfire Pro/Con?
by tc1446 - 11/22/19 08:54 AM
Possible to balance a bent steel wheel?
by johnnyh55 - 11/22/19 06:33 AM
Tablet question.
by 007 - 11/22/19 04:29 AM
dexos 1 vs dexos 2
by avi1777 - 11/22/19 02:33 AM
I had to lay it down...
by 02SE - 11/22/19 01:22 AM
Costco Car Buying
by rrretiree7 - 11/22/19 01:06 AM
Tesla Cybertruck
by E365 - 11/21/19 10:30 PM
hunter9296, Corslayth, oildud, Kylefl1, JDee71
69938 Registered Users
121 registered members (aquariuscsm, alteredtuning990, BeerCan, bdcardinal, avi1777, BAJA_05, 9 invisible), 2,452 guests, and 25 spiders.
Topics297,779
Posts5,122,370
Members69,938
Most Online3,589
Nov 2nd, 2019
Rate Thread
Ford 4000 oil specs #1977278 08/05/10 07:48 PM
B
Ben99GT Offline OP
B
Specifically oil specs for the power steering gear housing and power steering reservoir.
According to the specs the power steering gear housing calls for ESEN-M2C94-BA, ESW-M2C28-BA or M-4864-B and the power steering reservoir calls for ESEN-M2C92-A or M2C41.
From what I have been able to find ESEN-M2C92-A (power steering reservoir) is a 10W-30 hydraulic fluid and I think I have found a few sources for fluids that meet that spec, including Pennzoil. Any additional info. on this spec would be helpful.
The bigger problem is power steering gear housing (ESEN-MC28-BA), I haven't been able to find a fluid that meets that spec or what sort of properties this oil is. I think it might be a 90 weight gear oil, but I'm not sure.
Any help would be appreciated.
Edit: I meant to post this in the hydraulic fluid board.
2001 F150 Supercrew 4.6 - 321,000 miles- PP 5W-20/MC FL-820S
2011 Shelby GT500 SVTPP - 705 RWHP - PP Euro 0W-40/Wix 51372XP
Re: Ford 4000 oil specs [Re: Ben99GT] #1977379 08/05/10 09:33 PM
J
JimPghPA Offline
J
Don't know for sure, but give RedLine a call.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Ford 4000 oil specs [Re: JimPghPA] #1977537 08/06/10 05:32 AM
R
Rob_Roy Offline
R
The following is from Shell Lubematch:
2016 Ford Expedition EL Platinum
2016 Ford Expedition XLT
1999 Ford F350, V10
Re: Ford 4000 oil specs [Re: Rob_Roy] #1977699 08/06/10 09:05 AM
Steve S Offline
The Ford 4000 is a tractor? Have you tried an oil jobber to find a match.
Re: Ford 4000 oil specs [Re: Ben99GT] #1977874 08/06/10 12:08 PM
Jim Allen Offline
I have a similar tractor ('89 Ford 2810) and have used Rotella 10W30 engine oil, ISO 46 and 68 hydraulic fluid and the New Holland "134" (what the NH guys call it and what they will recommend you use) New Holland 134 and a generic 10W20 THF (trans hydraulic fluid) from Tractor Supply. They all worked equally well for the most part. I think if you look up any of the UTF (THFs) you will find they meet the specs you listed
I have rebuilt my steering system (which is almost the same as an older 4000) and it's really nothing special. Crude, actually. If you live in a hot climate, tend towards the heavier stuff, especially if you have a loader. My tractor has a loader on it, which puts a big strain on the front end and steering. Until I rebuilt the unit, the lighter grades tended to seep past the seals more.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
Re: Ford 4000 oil specs [Re: Jim Allen] #1977989 08/06/10 02:50 PM
B
Ben99GT Offline OP
B
Thanks, you have been a big help.
Re: Ford 4000 oil specs [Re: Ben99GT] #1978494 08/07/10 06:38 AM
daman Offline
If you want it simple that tractor can use any UTF that meets FORDs 134D spec,check the jug if it's listed you can use that in every sump but the engine.
"Always"....Mobil 1
Current fill: AFE 0w30
Re: Ford 4000 oil specs [Re: Ben99GT] #5038201 03/10/19 11:16 AM
K
Kamele0N Online Sick
Online Sick
K
Ford M2c41-a is ATF A suffix A....
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
