Originally Posted By: mechtech2
VVT was old in 1975.
There were heavily sprung centrifigally activated cam gears available for V8s that were around way before this.
They retarded the cam for high end power.
Unfortunately, they retarded the ignition timing, because the distributor ran off of the cam.
VVT, VCT? Just names. Variable valve and variable cam timing. the cam are advanced /retarded, the lift of the valves is regulated, or both together.
Each Mfr. does it differently.
BTW, I have a Ford Zetec 2.0 in a ZX2 and the VCT is on the EXHAUST CAM! It retards under cruise conditions to simulate an EGR valve - maybe get a longer burn time to tweak a bit more gas mileage.. I would love to have it on the intake - to do some good.
When they work right, they generally provide very real benefits.
Well, thankfully, I was not "old" in 1975 (in fact, I started high school that year). That said, I think this statement is a little misleading (I'm not claiming that's intentional). The concept of vvt was known by then, but because of the primitive computer systems available to control engines, it simply was not feasible to implement until about ten years ago (when, surprise surprise, it started appearing on production cars). In the near future, vvt, controlled by powerful computers, will be the order of the day for ALL vehicles.
