Anyone experience any problems using 5w20 vs 5w30?
I have '06 F150 5.4l 3v engine (45k miles). I have used 5w20 from the day I bought the truck new. In the past 3 oil changes, I have noticed the VCT phaser will begin to make a slight clacking sound on mild acceleration once I get past the 3k mile mark into the oci. It isn't anything horrible, but it is most noticeable when next to a wall (drive thru) and mild acceleration. I also notice it when revving up the engine to ~800 rpms. This occurs only when the oil is up to operating temperature and especially on very hot days.
From I have seen (UOA reports), 5w20 tends to shear down into the 7's cSt range. I guess this enough to cause the oil pressure to drop enough to cause the VCT phaser noise. BTW, I have used both Motorcraft blend and QS full synthetic 5w20 with the same result; although the QS was a huge improvement.
I will be going to 5w30 on the next oil change. Anyone experience any problems like this or others with 5w20?
