Read about it here:
LINK! (Page 8)
Here is what the product looks like...
Quote:
"Dominator Coolant Boost is formulated
with proprietary tiered surfactant technology,
providing quick and effective heat transfer
inside radiator and cylinder heads, which
results in reduced operating temperatures,
more efficient operation, increased horsepower
and significantly reduced engine warm-up times in cold
weather. Coolant Boost also contains a robust mixture
of corrosion inhibitors that protect the radiator, heater
core, water pump, cylinder heads, engine block and
intake manifold from the damaging effects of corrosion."
Temperature Reduction
Dynamometer Test
To test the temperature reduction capabilities of
Dominator Coolant Boost, dyno tests were performed
on a Chevy 350 cubic inch engine with an aluminum
block and cylinder heads. Running the test with both
straight water and water treated with Coolant Boost,
the engine was operated at 4,500 rpm until coolant
temperature stabilized.
Stabilized Coolant
Coolant Mixture Temperature
Straight Water 221°F
Water with Coolant Boost 202°F
Test results show water treated with Coolant Boost
provided a 19°F temperature reduction.
