Originally Posted By: mortician
I have a 1994 ford thunderbird sc with a 4.6L it will do 110 with no problem, now to the problem does anyone know how much oil a 4.6l holds? I am no mechanic but it has to hold at least 5-6 quarts right?
Unless you've done an engine swap, you either have a 94 SC with a supercharged 3.8L V6, or a 94 LX with a 4.6L SOHC V8. Both engines require 5 quarts of oil including the filter.
Originally Posted By: HangerHarley
Even though the SC is SUPERCHARGED H.O. 4...
The SC's (MN12 body) came with supercharged V6's. Turbocoupes (Fox body) came with turbocharged 4 cyl's.
-Rod
-Rod
