I contacted Amsoil regarding what weight oil I should run at the track and this is the response I got below.
Most guys at the track run the 50W as they say it holds up better when the oil starts to sheer down a grade after a weekend of racing.
What do you guys think? Run 40W or 50W for a track bike?
Thanks
From Amsoil Tech
We do not make specific recommendations for racing as there are too many variables. That said, unless you are having excess wear with the 10W40, I would continue using it as you will have more available power and speed if you are using it instead of the thicker 20W50.
Thank you for this opportunity to respond to your question(s). As always, please feel free to contact us again if we can be of further assistance.
Sincerely,
Byron Selbrede
Technical Services
Thanks
From Amsoil Tech
Sincerely,
Byron Selbrede
Technical Services
