Chevy malibu 2003 w/ 75, 000 miles
I notice that when the car starts from 0, if I step on the gas gently, 99% of the time, there is no ticking sound. However, say, if I step on the gas a bit harder, then I can usually hear ticking sound as the engine revs up to 2500 rpm until the gear is shifted.
This problem usually happens when the car starts from a very low speed to a higher speed and it doesn't happen if I make it rev 2500 rpm during highway drive.
The ticking sound started quite a while ago, maybe around at 50, 000 miles. That time, it didn't happen unless i stepped on the gas pretty hard to accelerate the car from 0 to say 30 mph. Recently, it happens more often. But it doesn't always happen.
btw, I changed the ATF at around 50, 000 miles, thinking it might the ATF needed to be changed. It didn't seem to help.
Sometimes, I find that the ticking symptom gets relieved a little bit after a fresh oil change. But this might be just coincident. Also, after I had my fuel pump replaced about 1 month ago, the ticking sound initially went away but now it came back.
Oh, forgot to say that this problem seems to happen much more often when the car has been driven for a while, say after 20 miles of driving. If I step on the gas quite hard when the car is cold, no ticking sound.
What could be the ticking sound then? The transmission? or, another ATF change? Thanks.
