I have used everything from Amsoil to havoline. Pennzoil platinum too, now this Pennzoil Ultra, is absolutely beautiful! All of my trucks love it. My chevy 5.3 V8 hasn't burned one drop (PU 5W-30/purolator pureone oil filter), at 5800 miles, thus far! My oil life monitor currently reads 27% oil life. The oil itself is a medium brown, slightly darker than honey. The engine runs so smooth, and my gas mileage is wonderful
(Shell v power/Pennzoil XLF ashless 2 cycle Marine TCW-3 in fuel). Either Penn Plat or Penn ultra is good, but I am going to give the edge to Penn ultra. My current mileage on my 03 suburban LT 5.3 V8 is 159,000 plus original miles.
Originally Posted By: Bill in Utah
Originally Posted By: strongt
Just stick with the 10W-30 Motorcraft Synthetic Blend that your running now. How's that not going to handle summer temps? If your really worry about then step up to a 10W-30 PP. I wouldn't worry to much unless you'll always in stop in go in 110+ plus weather.
Shoot my local area is already in 100+ temps and I'm not worryed about the MC5000 that I run. If your cars cooling system is running in good working order your engine temps stay the same.
Originally Posted By: Johnny
If you are having good luck with the Motorcraft 10W-30 stick with it. The heat of a Texas summer will not hurt it. I lived in Texas for 40-years and still have my t-shirt from 1986 that says I survived the summer of 86 when it was above 100+ from June 1 through the end of September and all I used that summer was good old Pennzoil 5W-30.
Oils have advanced greatly since then.
Same here! Both posts above have it covered.
Either a 5w-30 or 10w-30 will be just fine in the HOT temps (which is a lot easier to the engine than any cold temps. (and I'm talking about BELOW ZERO temps)
I'm in the middle of a 6000 mile trip in the Subaru with hours and hours of driving down the highway. All I did different is put in 10w-30 Pennzoil conventional instead of my normal 5w30. So far with 3200 miles I've used about 1/2 a quart (so I think since Subaru can not design a dipstick that is close to being accurate/easy to read)
The engine is doing well (as long as I stay away from 10,000+ ft grades then its 5000 rpm just to keep it going) oil is fine and I'll prob get a UOA just to see how the engine is doing at 4x,000 miles.
Take care, Bill
