Am i correct when i say you can mix different motor oil brands? you can mix different api service classes (sm, sl), you can mix dino, blend, and synthetic. as well as different weights
there is a discussion on another forum i visit about how ...
"30+ year chemical engineer and tribologist (do you need to google what a tribologist is?) who's entire career has been nothing but automotive oil says:
"if you mix oils, mix oils of the same brand as some addatives between the companies are incompatible"
Guess who I'm going to listen to. kthxbye
Unless of course you can provide credentials showing you know more about automotive oil than he does.
Dont mix oils from different manufacturers. the addin packs and addatives can be incompatible, causing the oil not to protect properly."
can you or can you not combine pcmo's without any problems.
