Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
Selling Vehicle CL / FB asking price
by madRiver - 02/24/20 11:24 AM
Cheapest place to get VOA with TBN?
by jayjr1105 - 02/24/20 11:18 AM
Selling my Mustang
by SilverGt - 02/24/20 11:05 AM
Tractor Supply more Mobil 1 clearance
by jayjr1105 - 02/24/20 10:51 AM
BG PLATINUM 44K
by UG_Passat - 02/24/20 09:51 AM
F-150 trucks in the past 10 years
by lancerplayer - 02/24/20 08:38 AM
What Fluid For Snapper Rear Axle
by Propflux01 - 02/24/20 07:25 AM
Played in the sand a little.
by Chris142 - 02/24/20 07:11 AM
oil extractors manual type
by passgas55 - 02/24/20 06:14 AM
Tesla Disrupts German Economy
by Y_K - 02/24/20 01:53 AM
Difference in Valvoline Asian red offerings?
by MichaelRS - 02/24/20 01:51 AM
RV's . give me the good and bad of owning one
by WhyMe - 02/24/20 01:36 AM
Removing silicone spray overspray/residue
by Calikura - 02/23/20 09:13 PM
Oil Questions for My New Mower
by CamBurt33 - 02/23/20 08:43 PM
2007 Vibe coolant smell
by philipp10 - 02/23/20 08:36 PM
PeterNST, SkinnRS, Bama65, wjamyers, L00btech
70793 Registered Users
110 registered members (1978elcamino, 4WD, alchargo, 2015_PSD, 2009Edge, 14Accent, 10 invisible), 2,417 guests, and 18 spiders.
Topics301,873
Posts5,204,338
Members70,793
Page 5 of 8 1 4 5 6 8
Re: They Call it "Lucas" Oil Stabilizer [Re: OVERKILL] #2384520 09/22/11 05:19 AM
Donald Offline
Originally Posted By: southernjeeper
I have been pleased with lucas oil stabilizer for a long time. More than 50,000 miles with adding the stuff. I think it helps........ A LOT.
230,000miles. I started driving my jeep since I was 16 when it had around 90,000miles.
Why do you think it needed Lucas to make it that far? My old 302HO has similar mileage and has never seen Lucas in its life. It's also seen 7,000RPM a few times and makes 100HP more than stock.
+1
If you want your oil to perform better, buy better oil. Don't use additives.
2015 Ford F-250 w/Powerstroke
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #2385919 09/23/11 04:24 PM
E
EricF Offline
E
@plotthound: the extra thickened oil took a while for the oil pump to get it flowing, and once it did it had to heat up enough to thin out to get thru the oil filter.
Just stay away from the stuff in the future.
to me it pours more like 140W
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
Re: They Call it "Lucas" Oil Stabilizer [Re: Donald] #2389014 09/26/11 10:01 PM
southernjeeper Offline
+1
wow. So what I have heard of better oil is Rotella T5 &T6. And the mobil 1 oils. I favored the Valvoline maxlife oil with the lucas for most of the mileage of my cherokee. I had the rear main done spring of last year and everything looked good.
I give LUCAS credit. That's all. I think my compression was a lot better with the lucas added. This go around I switched to the Rotella T5 and no lucas. Just to see any difference. Then if I see a difference I will stick with the HD oil instead of the HM oil.
What's sad these days we shouldn't worry about the oil in our engines (tho we actually do care) but SINCE we got da*n ethanol taking out our MPGs we can't blame our engine's performance on what oil we use. We can just blame the GOV'T!
my 2cent rant.
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #2389019 09/26/11 10:07 PM
O
OVERKILL Online Content
Online Content
O
I'd give your engine credit that it got that far despite the Lucas, not because of it wink
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #2389824 09/27/11 07:28 PM
I am not saying it was the lucas. I think it was mainly just keeping the oil changed every 3,000 miles. I have been using Valvoline maxlife for a longggg time which I think helps a lot.
Re: They Call it "Lucas" Oil Stabilizer [Re: southernjeeper] #2390135 09/28/11 09:18 AM
O
Online Content
O
Exactly. You used good oil and changed it often. That's far more important than any additive.
Re: They Call it "Lucas" Oil Stabilizer [Re: SLCraig] #2390355 09/28/11 12:41 PM
G
gomes512 Offline
G
Originally Posted By: SLCraig
As far as I know, it's a completely useless product that has actually been sold to a person or 2 somehow.
I wouldn't touch it with a 10ft pole.
Was going to say your count was a bit off, have you visited some of the Jeep forums?
Hehehe
I used that garbage once when I was in high school (I'll admit the wheel display got me) and it made my 4.0 clatter pretty loud upon first cold starts. Had to drain, that was a wasted OC.
Re: They Call it "Lucas" Oil Stabilizer [Re: OVERKILL] #2392856 09/30/11 09:51 PM
wow. I never really thought about it that way. I'll just see how the T5 does til the next oil change. Then I will decide whether to stay with the T5 or go back to the valvoline maxlife oil.
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3153402 10/12/13 12:33 PM
dixon700 Offline
Is there any analysis of the synthetic oil stabilizer? I just like to see numbers. I do an analysis every oil change, and Blackstone never said I shouldn't run it.. I've ran the Lucas since I got the truck 30k miles ago which I thought was for piece of mind...
04.5ram CTD lots of parts delvac15w-40 just delvac next time Donaldson elf7349 02 elantra gt castrol edge10w-30 oem filter
Re: They Call it "Lucas" Oil Stabilizer [Re: dixon700] #3153469 10/12/13 02:05 PM
demarpaint Offline
Can you post your UOA results with it in the oil?
God Bless Our Troops
Re: They Call it "Lucas" Oil Stabilizer [Re: OVERKILL] #3153560 10/12/13 04:00 PM
T
Trajan Offline
T
Shhhhhh....., they'll hear you.
Re: They Call it "Lucas" Oil Stabilizer [Re: LTrippett] #3154109 10/13/13 07:44 AM
L
Lapithes Offline
L
I would stay away from Lucas; I believe that there are few good additives on the market, but the viscosity of Lucas is just too thick -- and that can be done with just a higher viscosity oil. Unless it's a car that's going into the demolition derby or an engine that's on its last leg, I would opine that Lucas makes an engine wear out faster by using the product.
Re: They Call it "Lucas" Oil Stabilizer [Re: dixon700] #3154125 10/13/13 07:56 AM
spasm3 Offline
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2866328&page=1
Here are the numbers from that thread.
Here is the skinny on LOS
Unless listed all are 'Zero'
Lucas Virgin
TBN - 0.1
Visc - 615.3
FP - 435
Calcium - 3
Magnesium - 1
Phosphorus - 4
Zinc - 2
Rotella T / LOS 5 to 1 blend
TBN - 8.5
Visc - 115.4
FP - 420
Boron - 17
Silicon - 2
Calcium - 1442
Magnesium - 7
Phosphorus - 604
Zinc - 817
Look how much it diluted the zince level of rotella!
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: They Call it "Lucas" Oil Stabilizer [Re: southernjeeper] #3154318 10/13/13 11:50 AM
Clevy Offline
+1
my 2cent rant.
Your adding Lucas junk to your oil then spout off about ethanol costing you mileage.
That should be a sticky posted somewhere for all to see.
2006 Charger RT
Miles x 2 per oil filter
Re: They Call it "Lucas" Oil Stabilizer [Re: spasm3] #3154327 10/13/13 12:03 PM
dixon700 Offline
Now those oil analysis for Lucas was that the synthetic Lucas? I'll see if I can find some of my older analysis. The mist recent I changed a lot of engine parts and gave me some off the wall numbers.
