Car: 1993 BMW 850CSi V12 with AHK Rear Steering running off shared power steering fluid system (CHF11s)
Problem - Tiny but consistent CHF11s weepage on metal fittings on rear pressure piping for AHK. Changed some pipes already, but "unchangable" parts already had rust damage. CHF is just too [censored] thin. Causes ABS and ASC failure (as it affects ABS modulation) too.
Amount lost - About 500ml per 3wks (which is half a tin). Low fluid levels likely bad for PS Pump(s) and AHK Accumulator and Pressure system.
Ive read all the threads here about alternatives. Ive read the seemingly "no issues" reports from Audi drivers switching to ATF (Redline and Mobil 1). However Ive read first hand reports of written off 7 series and other BMWs on Bimmerforums from using the very same switch.
I would love to ditch 11s and put in something thicker. Im going to try the very marginally thicker and newer CHF202 again, see if its any better this time round (last time a major leak vented it on the motorway). Anyone got any comments to add?
