C carock Joined Mar 5, 2006 Messages 537 Location California May 23, 2010 #1 Is there a smaller size bypass filter for my motorcycle? I can fit a 3.75 X 4.5 inch filter in the available space. Last edited: May 23, 2010
G Gary Allan Joined Sep 28, 2002 Messages 39,799 May 23, 2010 #3 A EaBp90 on a BP80A mount should fit within those confines.
C carock Thread starter Joined Mar 5, 2006 Messages 537 Location California Jun 9, 2010 #4 The diameter of the EaBp90 is listed as 4.2 inches in diameter. It will not fit inside the 3.75 inch slot.
G Gary Allan Joined Sep 28, 2002 Messages 39,799 Jun 10, 2010 #5 Yeah. There are smaller bypass filters. I guess if you could find a 20x1.5M head. That's one wide gasket P550412 LUBE SPIN-ON BYPASS Application Details View Product Line Drawing Lube Filters Product Attributes Thread Size: M20 x 1.5 Length: 4.92" (125 mm) Outer Diameter: 3.64" (92 mm) Gasket OD: 3.43" (87 mm) Gasket ID: 2.08" (53 mm) Efficiency 50%: 5 Micron Primary Application: MAZDA SL5014V61
