A friend of mine has a 1989 Ford Probe that's making some clicking noises. I went to a Probe forum and they all think it's the Hydraulic Lash Adjusters because they have all had the same issue. Most of them are suggesting draining a quart of motor oil and then adding a quart of Automatic Transmission Fluid and then driving it for about 50 miles and then doing an oil change.
Is this a good idea? I was just going to suggest that she Sea Foam it and then oil change. Is this a common method, adding ATF to motor oil?
