My questions/discussions/debates have gone nowhere with other forums, so just thought I'd run this by everyone for opinions or real world experience.
The 8th generation Civic has the Maintenance Minder system to remind you of all of all of the fool-proof maintenance you need to do and when. That's not a big deal for me with 5k mile OCI's, etc., but my only issue is how to change ATF and WHEN?
Several owners recommend doing a "flush", which for this vehicle means drain and refill the ATF, while on the lift, run through all gears, R, and N, then repeat 3-4 times. I hear from several people that this COULD result in intermittent issues when you get to higher mileage.
There is an item on the Maintenance Minder that will tell you to change ATF. I hear it comes up around 60k miles, and the only procedure for doing this in the service manual is "drain ATF and refill using the dipstick hole". You refill with ~2.5qts. which is around 40% total volume.
Both of my Honda dealers say to do a single drain and refill every 30k miles and that is for the "severe conditions" schedule which is what they go by for ATF. I'm not really sure why everyone seems to think you should "flush" your ATF, or drain and fill 3-4 times, when no one representing Honda has instructed us to do this?
I'm at 40k miles on my Civic and I'm planning to do a single drain and fill, then again every 30k miles. Just wanted to gather everyone's thoughts on this. Thank you.
