ANALYSIS REPORT
WEAR
CONTAMINATION
OIL CONDITION
NORMAL
NORMAL
NORMAL
MOTORKOTE - New (Unused) Oil
Unit Make : {n/a} Date Rec'd : Dec 7, 2009 Sample Date : Dec 6, 2009
Unit Model : {n/a} Serial No: : {n/a} Time on Unit : 0 cyc
Comp Make : {n/a} Cust. Ref No. : {n/a} Time on Oil : 0 cyc
Comp Model : {n/a} Stub No. : WC-806723 Time on Filter : 0 cyc
RECOMMENDATION
This is a baseline read-out on the submitted sample.
Sample Date Current UOM
Time on Unit 0 cyc
Time on Oil 0 cyc
Time on Fltr 0 cyc
Oil Maint. n/a ---
Filter Maint. n/a ---
CONTAMINATION
{not applicable}
Sample Date Current Abn
Silicon --- ---
Potassium --- ---
Water (%) >4µm(c) --- 5000
>6µm(c) --- 1300
>14µm(c) --- 160
>21µm(c) ---
>38µm(c) ---
>70µm(c) ---
ISO 4406(c) 19/17/14
OIL CONDITION
Total Chlorine content (ASTM D808): 28.37% (283,700 ppm).
Sample Date Current Base
Boron ---
Barium ---
Calcium ---
Magnesium ---
Molybdenum ---
Sodium ---
Phosphorus ---
Sulfur ---
Zinc ---
Visc@40°C ---
Visc@100°C ---
Oxidation --- ---
TAN ---
TBN ---
WEAR
{not applicable}
Iron --- 20
Nickel --- 20
Chromium --- 20
Titanium --- ---
Copper --- 20
Aluminum --- 20
Tin --- 20
Lead --- 20
Silver --- ---
Report ID - WES660GUE [WCAMIS] 01577737 - Pg. 1 © 1996-2000 WearCheck Canada Inc. - All Rights Reserved. WCCF1160
Graphs
Viscosity @ 40°C
Particle Count Graph
TAN Level
If you have any questions concerning this sample report (work order no 01577737 ) please call 1-800-268-2131.
The leader in oil analysis
WearCheck International
Africa, Asia, Australia, Europe, North America ATTN: ED WESSELIUS
ED WESSELIUS
[email protected]
FAX ()-
Report ID - WES660GUE [WCAMIS] 01577737 - Pg. 2 © 1996-2000 WearCheck Canada Inc. - All Rights Reserved. WCCF1160
