Originally Posted By: Truckedup
Sorry for all the stupid questions........Your engine damage is different from what I've seen from oil starvation.The pump sucks air at full throttle from cornering G loads or a bad pump pick up and the crank bearings wipe out instantly.Maybe even spun bearings.Your bearings appear no where near that.I'm just surprized that the bearings kinda survive and the roller cam ,that should tolerate a "pressurized" oil interuption, has a drastic failure.
Then again,I've learned something new.
This was probably a "between shift" RPM spike which meant the engine had no load on it. The only part that is constantly loaded in this case is the valvetrain.
The pump didn't "suck air" per se, rather it lacked the ability to pump OIL due to cavitation.
Have your failures been observed on SBC's by chance? I ask because the Ford Windsor engines and the GM Small Block oil different components first. The GM Small Block IIRC oils the cam first, whilst the Ford Windsor engine oils the crank first. So the first thing to starve for oil with an SBC is going to be the crank and rods. The first thing to starve for oil in an SBF is going to be the valvetrain.
Here's a GM Smallblock oil system diagram:
Here's a Ford Smallblock oil system diagram:
