If your dead set on running a synthetic I'd stick with 5w30 and go with Pennzoil Ultra, Redline, or Amsoil. You can't go wrong with either of those, just depends on how much you want to spend. For a filter I would use either a Purolator PureONE or the OEM Honda S2000 filter made by Toyo Roki. The S2000 filter will fit your Civic just fine and is a larger and much better filter than the one made by Filtech that Honda uses on all the other models. It has the letters "PCX" in the model number, the other one uses the letters "PLM".
If you want to save some cash to use elsewhere on the car you would be fine running a good conventional oil. PYB 5w30 can handle the RPMs.
Originally Posted By: CATERHAM
Welcome to BITOG.
5W-20 is now the spec' oil for your engine but I'd upgrade to a 0W-20.
Honda's own 0W-20 is an excellent oil with a very robust additive package.
This is the second time you have claimed that 5w20 is now the spec oil for the Honda K series motors. I have searched the web and can not find any proof of this. 5w30 is still clearly recommended for the Si models in the states.
Please provide a link or PDF file that shows Honda recommending 5w20 for the Si motor.
