Torque Pro app for iPhone?
by Ed_Flecko. 03/23/19 08:18 AM
Sharpening Drill Bits
by ET16. 03/23/19 08:03 AM
more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
95 registered members (beanoil, 53' Stude, Audios, alarmguy, advocate, 4WD, 6 invisible), 1,651 guests, and 56 spiders.
Topics286,273
Posts4,905,733
Members67,589
Most Online2,967
Mar 10th, 2019
AC Leak Dye Stains? #1868140
04/23/10 09:23 AM
04/23/10 09:23 AM
Cape Town , South Africa
GTO52 Offline OP
GTO52  Offline OP
I had a shaft seal blow on my AC Compressor.
I had leak detecting dye in the gas.
It left horrible green stains on my white paint work on the underside of my bonnet.
Nothing seems to get rid of the stains?
Any ideas on how to remove the stains?
1995 Toyota 2.4SRX Hilux(22R Engine)
2002 Toyota 2700i Hilux 4x4(3RZ-FE)
1985 Suzuki DR600S
1984 Honda ATC200ES BIG RED
Delo 400 15w40 in all of the above
Re: AC Leak Dye Stains? [Re: GTO52] #1868146
04/23/10 09:28 AM
04/23/10 09:28 AM
VA
ctc Offline
ctc  Offline
VA
Have you tried to buff it out with some polish or maybe rubbing compound?
Re: AC Leak Dye Stains? [Re: ctc] #1868149
04/23/10 09:30 AM
04/23/10 09:30 AM
GTO52 Offline OP
GTO52  Offline OP
I tried polish but not rubbing compound, I have some burnishing cream would that work?
1985 Suzuki DR600S
Re: AC Leak Dye Stains? [Re: GTO52] #1868223
04/23/10 10:50 AM
04/23/10 10:50 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Brack cleaner.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: AC Leak Dye Stains? [Re: Chris142] #1868314
04/23/10 12:32 PM
04/23/10 12:32 PM
GTO52 Offline OP
GTO52  Offline OP
I have never used brake cleaner before, will get some and give it a try.
Does brake cleaner have a lot of other uses besides cleaning brakes?
1985 Suzuki DR600S
Re: AC Leak Dye Stains? [Re: GTO52] #1868387
04/23/10 01:57 PM
04/23/10 01:57 PM
VA
ctc Offline
ctc  Offline
VA
Yeah but I'm not sure you want to use it on paint :). I would test on something other than your car first.
I know carb cleaner removed the paint right off my screw drivers once.
Re: AC Leak Dye Stains? [Re: GTO52] #1868788
04/23/10 08:56 PM
04/23/10 08:56 PM
Plattsburgh, NY
OilNerd Offline
OilNerd  Offline
Plattsburgh, NY
Try Glo-Away Fluorescent Dye Cleaner by Tracer Products.
It works great for A/C dye cleanup, though I've never used it on painted surfaces, so test in an inconspicuous area first.
Buddy's Wife: "Why do you need to get a V-8 Mustang?"
Buddy: "Because I can't get a V-12 Mustang!"
Re: AC Leak Dye Stains? [Re: OilNerd] #1868899
04/23/10 10:41 PM
04/23/10 10:41 PM
Chris142 Offline
Chris142  Offline
If brake cleaner wont do it I dunno. We use it to clean the dye off of stuff under the hood.
