Torque Pro app for iPhone?
by Ed_Flecko. 03/23/19 08:18 AM
Sharpening Drill Bits
by ET16. 03/23/19 08:03 AM
more dumb questions!! infiniti Q50
by Robertslowpoke. 03/23/19 06:23 AM
VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Zahndkile, duradick, Harold1031, Skendread, NGK
67590 Registered Users
89 registered members (Audios, BeerCan, advocate, alarmguy, 4WD, berlyn, 6 invisible), 1,587 guests, and 56 spiders.
Topics286,273
Posts4,905,725
Members67,589
Most Online2,967
Mar 10th, 2019
Page 2 of 2 1 2
Re: Cleaning decades old oil stains off concrete floor [Re: Malo83] #1959155
07/19/10 08:53 PM
07/19/10 08:53 PM
waxahachie, tx
ranger52 Offline
ranger52  Offline
waxahachie, tx
Try applying some lacquer thinner on the oil spot. Immediately after the lacquer thinner, put some oil dry or kitty litter on the spots to absorb the lacquer thinner and the dissolved oil. Leave it a day and sweep it up later.
Re: Cleaning decades old oil stains off concrete floor [Re: ranger52] #1960441
07/21/10 04:30 AM
07/21/10 04:30 AM
San Jose, California, United S...
John_Corey Offline
John_Corey  Offline
Hi ranger,
I wonder if this procedure might work on oil-stained concrete. My brother in-law parked his MKII in my driveway and, as it befits a vehicle of British pedigree, it left a considerable puddle of oil behind. Unfortunately, the oil has already been absorbed into my brand-new driveway, and all the scrubbing with soapy water did not help much.
Cheers,
-J
Re: Cleaning decades old oil stains off concrete floor [Re: John_Corey] #1960993
07/21/10 02:28 PM
07/21/10 02:28 PM
Tn.
CourierDriver Offline
Tn.
we use to use tide with bleach powder , worked like a charm
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Re: Cleaning decades old oil stains off concrete floor [Re: CourierDriver] #1962009
07/22/10 10:54 AM
07/22/10 10:54 AM
waxahachie, tx
ranger52 Offline
ranger52  Offline
waxahachie, tx
In my experience, the lacquer thinner and litter will remove oil stains from concrete.
Re: Cleaning decades old oil stains off concrete floor [Re: CourierDriver] #1962195
07/22/10 01:28 PM
07/22/10 01:28 PM
waxahachie, tx
ranger52 Offline
ranger52  Offline
waxahachie, tx
In my experience, the lacquer thinner and litter will remove oil stains from concrete. You will notice the place at first. However, I do not remember my attention being called to those places after a while.
Re: Cleaning decades old oil stains off concrete floor [Re: stuntboy79] #1968947
07/28/10 11:41 PM
07/28/10 11:41 PM
NSW, Australia
Craig750 Offline
Craig750  Offline
NSW, Australia
I use standard petroleum engine degreaser first.
Then I mix in a slurry of clothes washing powder and water. You want the slurry to stay in place and hold the water
Then a stiff brush and scrub it in for a few minutes and then let it soak for a few hours to a couple of days. Keeping the area wet.
After a good soaking I then hose it down. You can see the stains when it is wet but after drying it is hard to see them.
WARNING WILL ROBINSON: I AM NOT A CHEMICAL ENGINEER AND DO NOT KNOW IF MIXING DEGREASER AND LAUNDRY SOAP POWDER IS DANGEROUS.
Re: Cleaning decades old oil stains off concrete floor [Re: stuntboy79] #1981162
08/09/10 08:42 PM
08/09/10 08:42 PM
ks, wichita
morris Offline
morris  Offline
ks, wichita
go somewhere where they are building a new road, from the ground up, not just repaving, ask the boss if he knows where you can find fly ash. its a gray power. put it on the floor sweep back and forth, pick up dump out, and add some to the floor let it set and sweep some more.
Re: Cleaning decades old oil stains off concrete floor [Re: stuntboy79] #1981167
08/09/10 08:50 PM
08/09/10 08:50 PM
ks, wichita
morris Offline
morris  Offline
ks, wichita
to, papa bear, in the late 60s i worked with an old mech. he used battery acid to clean old pot metal carbs that sat outside. but you had to have running water to rinse the acid off at just the right time. BUT it doesnt work on aluminum
Page 2 of 2 1 2
