hello, what is the corrrect or reccomended way to change the tranny fluid on a 06 lucerne with a 3.8 L engine? is it a simple drain plug or do I need to remove the pan and get a new gasket.. also what fluid should I refill with,,,thanks,,,also what interval should this be done??/
