I do just that every oil change to prime the oil system before starting. Pre-fill the filter as much as possible then crank until I get an oil pressure reading (usually 10 seconds or so).
That's the only time I do it though, once the system is primed and the ADBV is doing its job I don't see much of an advantage.
