This is a 2004 Altima 3.5L SE. Car still has the original OEM battery. Car sat for about 3-1/2 days, and went to start it and the battery would barely turn over the engine. After 2 or 3 engine rotations it died. Measured the battery voltage and it was ~ 10.6 volts ... dead. First time this has ever happened, and I've let it sit much longer than 3 or 4 days before.
Charged the battery and got the car started. Measured the charging voltage across the battery and it was ~ 14.3 volts @ idle ... normal.
Drove the car for the next 2 or 3 days and the battery seems to start the car fine.
Did a parasitic current draw measurement with an accurate Fluke DVM while the car was off, key out and locked. Current draw was a stable 70 mA.
Does anyone know if 70 mA is normal for this Nissan Altima with the car off, key out and locked up? Seems a little high, but maybe per spec (which I don't know - not in manual). If 70 mA is normal, then I guess it's time for a new battery. Should get one anyway based on the fact the original is ~ 7 years old.
